30 Hi viz vests
Re: 30 Hi viz vests
Any one print Hi Viz vests need a price for 30 please image and text on back please
Re: 30 Hi viz vests
here is the image they want guys thanks for all the PM's [ATTACH=CONFIG]606[/ATTACH] have given black back so you can see white outline
- vB_ID:606
- full a4 hi vis black copy.jpg (56.45 KiB) Viewed 43 times
- vB_ID:605
- Hi viz port.jpg (49.29 KiB) Viewed 43 times
- full a4 hi vis black copy.jpg (56.71 KiB) Viewed 43 times
- Hi viz port.jpg (49.6 KiB) Viewed 43 times
Re: 30 Hi viz vests
Ok guys thanks for pms here is image so you can get better idear [ATTACH=CONFIG]607[/ATTACH] black back is so you can see white outline
- vB_ID:607
- full a4 hi vis black copy.jpg (56.5 KiB) Viewed 43 times
- full a4 hi vis black copy.jpg (56.79 KiB) Viewed 43 times
Re: 30 Hi viz vests
That artwork wouldn't be cost friendly for screen printing - if you can do it without the white you might want to consider sublimating them.
Re: 30 Hi viz vests
thanks JohnJohn G;32290 wrote:That artwork wouldn't be cost friendly for screen printing - if you can do it without the white you might want to consider sublimating them.
Re: 30 Hi viz vests
Only way I can see it working is using subli-flock, this will give you the white but would be more expensive.
Re: 30 Hi viz vests
that could be done with inkjet dark paper
stu
stu
RICOH GX 7000 ROLAND GX24 ROLAND VP300
Re: 30 Hi viz vests
I'd totally re-design it to match their website, keep it to the Red and blue with maybe the tel number in black.
It will look a lot more professional than what you have
and you can sublimate them!
