I have a question regarding Multi Flex from Xpres. When the flex is pressed at the correct time of 15 seconds and then hot peeled, does anyone repress the design again for a few more seconds?
Thanks, Matt
Multi Flex
Re: Multi Flex
I do that with every flex. after cold/hot peel I repress for another 5sec.
Re: Multi Flex
Thanks for that Paul & John. I took receipt of a new heat press from xpres on Wednesday and will be using it shortly.
Re: Multi Flex
I re-press also with most jobs. Even with hot peel vinyl/flex/flock there's got to be some degree of pull from the garment no matter how well it's bonded, giving it a re-press does no harm (unless someone knows different?) and as John says it re-flattens the edges.
