Paper Question
proprints
Re: Paper Question
Post by proprints »
I am now going to sound very stupid, but here goes.
Which side of the paper do you pint on the smooth or rough? Unfortunatly I have some cheap paper (I thought it was all the same) Oh well will purchase some after I have played with the printer for a bit.
Also with a Ricoh 3300 does the paper go in the tray shiny/smooth side up or rough side up
Cheers
Steve
Re: Paper Question
i dont know about your paper but if this would me I would test first brighter side of the paper. and second answeris printable side down ;)
JackB
Re: Paper Question
Post by JackB »
I use the GX7000 with Xpress paper and it goes in shiny side down as paul says, you will soon see if you print and press the wrong side.
Jack.
JSR
Re: Paper Question
Post by JSR »
I use Xpres paper (print on the bright white side), TruPix (print on the bright white side), and TexPrint (print on the side that doesn't have 'TexPrint' stamped all over it).
I've not seen a paper with a "shiny side".
John G
Re: Paper Question
Post by John G »
Xpres paper on any ricoh - white side down
JackB
Re: Paper Question
Post by JackB »
JSR;31694 wrote:I use Xpres paper (print on the bright white side), TruPix (print on the bright white side), and TexPrint (print on the side that doesn't have 'TexPrint' stamped all over it).
Oops! sorry I meant the brighter side.:redface:
Jack.
schizowife
Re: Paper Question
Post by schizowife »
Sometimes its really hard to tell which side is the printable side on the sub papers. The best way to tell is to lick the end of your thumb and forefinger and pinch the corner of your paper. The print side will feel tacky and stick more to your thumb/finger :)
Martinx
Re: Paper Question
Post by Martinx »
Gently fold one corner over to compare it in natural daylight. Some papers can be a real pain. I'm an xpress paper fan myself.
