B1100 printing problem
Re: B1100 printing problem
Hi guys
I tried to print using my b1100 but there was not yellow, i did 4 head cleans with nozzle check after everyone and nothing, i read the guide (one BMS recommend) did the syringe in the top that didn't work tried the syringe in the bottom (without needle on) that hasn't worked,
now when i print i've got no black.
what should i be doing?
Matthew
Managed to sort it some how, but when printer was doing test print it has snapped the white bracket that holds the 5 tubes in place on top of the cartridges, anyone know where i can get one of these
Matthew
Just put down some blue tak on the printer then nestle the tubes on top and then put another layer of blue tak on top. Quick and simple solution i say
Tried a really sticky double sided tape and that didn't work, i'm just frightened when it's printing the tubes are going to jam as they are all over the place when it prints
Matthew
- Has thanked: 11 times
- Been thanked: 9 times
I'm sure one of the Suppliers on here could get one for you, failing that try here:http://www.cityinkexpress.co.uk/ciss-spares
Cheers Justin, i'll wait and see if a supplier can help, if not try your linkJustin;30844 wrote:I'm sure one of the Suppliers on here could get one for you, failing that try here:http://www.cityinkexpress.co.uk/ciss-spares
Matthew
Does the printer still print? If so then it's not a critical part of the electronics that has broken. Is this just the bit that holds the tubes flat on the cartridge block? Have you tried hot glue to glue it back - it's usually quite strong. The only option the main suppliers would have is a new cartridge and tube full assembly.Alligiftor;30841 wrote:Managed to sort it some how, but when printer was doing test print it has snapped the white bracket that holds the 5 tubes in place on top of the cartridges, anyone know where i can get one of these
I've tried to print once and tubes are getting thrown all other just frightened they get caught, yeah it's the bracket that holds the tubes on top of the cartridges.bms;30861 wrote:Does the printer still print? If so then it's not a critical part of the electronics that has broken. Is this just the bit that holds the tubes flat on the cartridge block? Have you tried hot glue to glue it back - it's usually quite strong. The only option the main suppliers would have is a new cartridge and tube full assembly.
i'm sure i've got a glur gun somewhere.
i not even sure how it broke to be honest
Matthew
I thought these clipped into place...Alligiftor;30863 wrote:I've tried to print once and tubes are getting thrown all other just frightened they get caught, yeah it's the bracket that holds the tubes on top of the cartridges.
yeah it has a bracket stuck to cartridges then you clip a bracket on top to hold tubes
Matthew
