a. Has any one done theses if so how long do I press for, is there anything I should be aware of when do them. Is there a template for these.
b. How long do I press the bibs for, I'm at the shop tomorrow and I image it will be quiet so I'm going to have a bash at these as I've had them long enough and the day will not seem so long
Sublimation Pennants and bibs
Re: Sublimation Pennants and bibs
Bibs / Penants will be the same...Press at 190 degrees Celsius for 50/60 seconds, medium pressure.
Thanks Martin I brought them ages ago and put the instructions away safe to safe, For the pennants, would I use a a4, sheet as the pennants would completely covered in even pattern or would the ink go on the gold bit.
I had a few tries but fail on all accounts, First one the colour didn't lie evenly across the pennant. The pressure was right. I tried pressing for a longer time. the back was scorched and at the top of the pennant there was white bits, tried a few more times but same problem. There was also little bits of white near the edge, no two pennants was the same the white bit was just there but in a different place, Either my pressure was to hard the pennant edges looked flatten and discoloured. never got around the bibs as I was busying burning the pennants
