Ricoh 3300
AJLA
Re: Ricoh 3300
Post by AJLA »
Anyone using one with Corel and do you use a ICC profile or not??
John G
Re: Ricoh 3300
Post by John G »
Not using one but you should be using powerdriver, not icc profile, with this printer.
mgibbs
Re: Ricoh 3300
Post by mgibbs »
I use the GX7000 with Corel and Powerdriver.
Mark
Kaz
Re: Ricoh 3300
Post by Kaz »
Same as Mark.
If the ICC profile is switched on at the same time as using powerdriver, the colours come out all wrong.
I know from bitter experience a few months back :(
John G
Re: Ricoh 3300
Post by John G »
I don't think you install the profile as there is no need - just the powerdriver. I'm sure Martin will be along soon to confirm this!
Re: Ricoh 3300
AJLA;28121 wrote:Anyone using one with Corel and do you use a ICC profile or not??
With the Ricoh printers - just install PowerDriver. No need for the ICC profile as well. PowerDriver makes life so much easier and no messing around with profiles.
AJLA
Re: Ricoh 3300
Post by AJLA »
Knew you'd be along thanks for confirming that Martin
JSR
Re: Ricoh 3300
Post by JSR »
bms;28134 wrote:PowerDriver makes life so much easier and no messing around with profiles.
The easier things are perceived to be, the more detached we become from understanding how things work.
Scotty@BMS
Re: Ricoh 3300
Post by Scotty@BMS »
JSR;28140 wrote:The easier things are perceived to be, the more detached we become from understanding how things work.
As Blackadder said; "I'm afraid that I'm one of the people who are happy to wear cotton, but has no idea how it works!"
