need help with signblaze
Re: need help with signblaze
Hi there,
ok, so I've got my first cutter and doing some test.
got design from corel draw, copy it to sign blazer. everything goes nice but every line is cutted three times with minimal distance (about 1/3 mm)
cant understand why. I've checked design in corel draw and i'm sure it's only one line there
please help
please help
it may be one line but it may be coesed by "stroke" I have done it once and on earth could not find out why was that
can you select your logo or whatever it is and just change the lines as a "hair line"?? I am not corel guru. just trying to have some idea
Not sure about signblazer but you may have to convert to curves then export out of coreldraw as eps then import it into your cutting program.
This might help.
This might help.
I think I found a reason. looks like design in corel draw has an outline switched on. then signblazer recognize it as two different objects to cut (outline as a second object). could switch off outline in corel draw but it's a part of design :/
ok. now I've got it
in Corel Draw select object, then go to Arrange/Convert Outline to Object, then switch off outline (as new one will be automatically created), select all objects (base one and new created from outline) and go to Arrange/Shaping/Weld --- that's how permanently change outline into part of object
Yes, everytime you put an outline onto an image your plotter will detect it and cut to that line.
- mrs maggot
caught me out a few times in the beginning, as well, glad you have it sorted, always something new to learn, sometimes view the image in corel draw in wireframe, just to check
pitkin2020
If you don't need the outline, which if your cutting vinyl you shouldn't then why not just remove straight away, no need to weld anything then?kris_hm;27960 wrote:ok. now I've got itin Corel Draw select object, then go to Arrange/Convert Outline to Object, then switch off outline (as new one will be automatically created), select all objects (base one and new created from outline) and go to Arrange/Shaping/Weld --- that's how permanently change outline into part of object
Its always worth converting to curves too before exporting and opening in sign blazer as you can sometimes get a double line in SB when you open it, which if you don't realise its there it will cut the same thing twice lol
pitkin2020 - I needed the outline as in some places it was a part of design. anyway, sorted now
thanks for all suggestions
pitkin2020
No probs, its just unusual to use an outline as part of the vinyl design as usually its just a hairline so even when cut there will be noting there as there is only 1 side (1 line) to cut, unlike a contour which will be an actual shape around the design. Glad you got it sorted.kris_hm;28052 wrote:pitkin2020 - I needed the outline as in some places it was a part of design. anyway, sorted now
