Re: speed and PRS ??
Posted: 05 Aug 2011, 14:03
by kris_hm
Hi,
My new cutter just arrived
and it's my first one as well so probably will have a lot of questions to you
for start just two:
1. what speed and PRS (pressure??) should I set up on cutter ??
2. I can manually adjust blade, could you please advise how much it should stick out from it's cover ??
thanks !
Posted: 05 Aug 2011, 14:04
by mgibbs
What cutter is it?
Mark
Posted: 05 Aug 2011, 14:26
by kris_hm
Posted: 05 Aug 2011, 14:35
by Reg
Speed 300 Pressure 65 - 70 Blade just adjust dragging across a piece of vinyl till it just scratches the backing paper
Posted: 05 Aug 2011, 22:46
by Paul
speed in my is set at 165 ) as soetimes it can cut realy rough small elements. so I slower it down
but i ma not in rush any way...
Posted: 17 Feb 2012, 00:55
by kris_hm
Hi there,
another silly question
can I use my Flex blade to cut paper?? or do I need different blade??
I would like to cut business cards so probably rather bit thick paper
Posted: 17 Feb 2012, 08:25
by John G
You may kill your plotter doing this, they are not designed to cut card - also your blades won't last 2 minutes. Buy a cheap guillotine to cut your cards down.
Cheers John
Posted: 18 Feb 2012, 15:26
by kris_hm
John G;40101 wrote:You may kill your plotter doing this, they are not designed to cut card - also your blades won't last 2 minutes. Buy a cheap guillotine to cut your cards down.
Cheers John
I was thinking about cutting cards in unusual shapes :/
