speed and PRS ??
kris_hm
Re: speed and PRS ??
Post by kris_hm »
Hi,
My new cutter just arrived :) and it's my first one as well so probably will have a lot of questions to you ;)
for start just two:
1. what speed and PRS (pressure??) should I set up on cutter ??
2. I can manually adjust blade, could you please advise how much it should stick out from it's cover ??
thanks !
mgibbs
Post by mgibbs »
What cutter is it?
Mark
Reg
Post by Reg »
Speed 300 Pressure 65 - 70 Blade just adjust dragging across a piece of vinyl till it just scratches the backing paper
speed in my is set at 165 ) as soetimes it can cut realy rough small elements. so I slower it down :) but i ma not in rush any way...
kris_hm
Post by kris_hm »
Hi there,
another silly question :)
can I use my Flex blade to cut paper?? or do I need different blade??
I would like to cut business cards so probably rather bit thick paper
John G
Post by John G »
You may kill your plotter doing this, they are not designed to cut card - also your blades won't last 2 minutes. Buy a cheap guillotine to cut your cards down.
Cheers John
kris_hm
Post by kris_hm »
John G;40101 wrote:You may kill your plotter doing this, they are not designed to cut card - also your blades won't last 2 minutes. Buy a cheap guillotine to cut your cards down.
Cheers John
I was thinking about cutting cards in unusual shapes :/
