setting up the latte mug design
mrs maggot
Re: setting up the latte mug design
Post by mrs maggot »
I have a latte template, but assume i need to curve everything also in line with the latte template so it will appear straight when pressed on the mug, can anyone show me how a template should look so i can get an idea how to lay mine out - thanks
i have seen the conde video showing the 15%, 10% etc curve, but my template does not have that on, so any advice would be good
laura
smitch6
Post by smitch6 »
Brill question Mrs M
it's something i really struggle with and would love to see if there is a simple answer
i've done 3 latte mugs since i started back in jan and each one took about 2 or 3 attempts it's a real pain doing them but they look so nice when you get them right
mrs maggot
well ive set them up as per the conde video, and set up my own guide lines, once i have the printer sorted i will see what happens, ive not pressed a latte yet ......
