Would this even be possible with cut vinyl.... :/ ?
gtd91
Re: Would this even be possible with cut vinyl.... :/ ?
Post by gtd91 »
Hey,
first newbie question coming up :P
Basically im looking to produce the popular leavers hoodies design that is going round at the moment, Im not really sure the best way to go about something this complicated , whether to mix certain techniques or if i could get away with one system.
Here is an example of what i am looking at :
http://www.actifwear.co.uk/images/sce/g ... GP0913.JPG
Any advice would be very appreciated on this :)
Thanks in advanced DSF people
accdave
Post by accdave »
Haven't you left it a bit late, most left in June :)
I can tell you from experience dong the task in vinyl is extremely difficult and not worth the time spent on it. You need to get them screen printed or transfers made
AdamB
Post by AdamB »
Owwwwwwwwwwwwwww - I've weeded some stuff and many my designs are quite fiddly but this would take AGES to weed and like accdave said - the time spent weeding it wouldn't be viable - definatley a screen print job as the names will all be the same (or a plastisol transfer made that you can press yourself when required).
JohnG may be the best to advise on the best method for this?
mrs maggot
Post by mrs maggot »
i would have plastisol transfer made up for it, leavers hoodies normally 50 plus at a time, you are looking at £4/£5 (rough estimate for smaller qtys) a time for the prints, plus set up cost with the printer, no weeding etc - and you can still personalise the front yourself. leavers hoodies have all been done this year round here, we normally do them to co-incide with the proms - parents know they have to spend out on the prom so the extra for the hoodie/t shirt just gets added to their bill
John G
Post by John G »
As said above, it wouldn't be possible to weed all that - plastisol transfer, screen print or DTG would be the way to go.
gtd91
Post by gtd91 »
Thanks for the advice everyone, i kinda had a feeling the weeding would mean id have to start now for them to be ready next year.
And i wasnt planning on doing this years hoodies, just to prepare myself and learn the trade for next years leavers.
So using plastisol transfer for the tricky '2012' bit and then using cut vinyl for the unique names of each student would be a viable option ?
Also would the plastisol x-fer suffer in the wash :P ?
mrs maggot
its the only way to do it if not having them screened, or DTG - the transfer is basically like a screen print you put on yourself if that makes sense, they wash and wear very very well, i do hundreds of them every year - for all sorts of events, then any personalisation is easy with vinyl added
gtd91
Post by gtd91 »
So that's that settled then, Ill get reading over the forum about the x-fers and go from there :)
Thanks for all the help people, i really needed that first push in the right direction
If the design was no more than A4 then could could do this with the Magic Touch WOW papers. You can print white on any colour by not doing the final colour transfer bit of the process.
stuart
Post by stuart »
laura
who do you use for your plastisol transfers
cheers
stu
RICOH GX 7000 ROLAND GX24 ROLAND VP300
