Hi All I have recently started printing some mugs with text on but the text seems to be coming out less than crisp does anyone have any tips as to how to get a sharp image?
My set up is an Epson 1400 with Trupix Papers & Sawgrass ink with mugs from BMS - pressing etc seems fine with photos and the like and works ok with text its just not as sharp as I would like it - particualry for black text.
I usually dip the mugs in tepid water after pressing to stop additional gassing of the inks etc.
Software I use for rendering the images is Adobe Elements.
Any guidance greatly appreciated thanks!
Getting Crisp Images Of Text On Mugs
whitesquizzel
- Has thanked: 11 times
- Been thanked: 9 times
Re: Getting Crisp Images Of Text On Mugs
What press are you using, time & temp? Which mugs, 10oz European?
Would be helpful to see a picture of a problem printed mug. Can you put one up here?
I found the style of font made a big difference, so I am just careful what font I use now...just because it looked clear on my screen didnt mean it looked as good on the mug....If I see a font, I play around with the size and spacing of it etc, or I try to find a crisper version on the net...
All fonts are crisp - never had a blurry one unless it was supposed to be like that (like papyrus for example)
whitesquizzel
Justin;26269 wrote:What press are you using, time & temp? Which mugs, 10oz European?
Thanks for the reply and sorry for my delay. Am using a Tigger mug press for 180 seconds - seems to press photos etc OK and it does press the text ok its not fading its just not as crisp as I would like. Using 10oz Euro mugs
whitesquizzel
