So that's .psd files. What about .ai .cdr .dds
and then there's all the other features i.e. transparency
Transparency support. For each file format you can define how MysticThumbs generates thumbnails:
- No transparency
- Transparent - so you see the folder/desktop behind the thumbnail
- Checkboard - gives you a distinctive backdrop behind the thumbnail that shows the transparent or semi-transparent areas.
Image viewer via View context menu for all supported and enabled image types.
Icon overlays enable/disable and selectable per file format / extension.
Maximum image size - performance enhancement to prevent thumbnail generation for excessively large images. Definable for each file type.
Scale Up - for small images allows the generation of full size thumbnails for thumbnails larger than the image.
Thumbnail cache clear - to easily clear the entire thumbnail cache.
Per image refresh - refresh the thumbnail of images if required.
Per image options (transparency/scale up) - some images may not conform to the default options for that image type - use this context menu option to override the default.
Folder icon enhancement.
- Vista and Windows 7 do not refresh the folder icon for image folders very well. MysticThumbs improves upon this.
- Use the refresh option on a folder to update the folder's images and it's icon.
- Generated thumbnails of images automatically update their parent folder icon.
System tray applcation to inform you when thumbnails are being generated by MysticThumbs. Quick access to the control panel for options.
Windows supported image types enhancement. MysticThumbs can override the default Windows supported image types (jpeg, png, tiff) so you can get the benifits of MysticThumbs features such as transparency, maximum image size etc.
Color profile support.
PSD Photoshop images all formats and bit depths supported. Internal thumbnail used for excessively large images.
PSP Paint Shop Pro images, all versions supported.
DDS almost all formats and bit depths supported for all your game textures. Cube maps represented as a cross.
Enhanced support for system supported images, PNG, JPG, BMP, TIFF, GIF - all the benefits of MysticThumbs customization such as transparency support.
Thumbnail adornment options - drop shadow or disable.
Network thumbnail handling support.
Localization - 15 languages supported.
Plugin support for custom file formats.
Automatic updates.
Phew, that took some typing
