Re: polymer mugs - first review!!!
Posted: 11 Jun 2011, 20:50
So - I made some time today to test print some polymer mugs that I had got on my last order from BMS (sample 6 pack plus puck).
Before I start, apologies - I forgot to take photos but I'll try and get some up tomorrow of the mug I did (EDIT: images now added).
Firstly after I had found my mugs (apologies to BMS, they were that light I never knew they were in the box) I realised what people meant by the weight. Although they feel very light, there is a quality feel about them. They are the same size as an 11oz (European mug) and the puck fits inside very, very snuggly.
[ATTACH=CONFIG]315[/ATTACH] [ATTACH=CONFIG]317[/ATTACH] [ATTACH=CONFIG]316[/ATTACH]
A closer examination of the mugs reveal that they have a very glossy outer and the sides seemed very straight (always a good starting point). I noticed the symbol on the bottom of the mug that I believe is the SunFly symbol (if I'm not mistaken?) (IMAGE 3) so I was pleased that I was finally trying something that I had looked at many months ago! My first thoughts of a plastic mug was, well - just that really. What I mean is that I thought the mug would be one piece of plastic that had come out of a mould or something. As I looked at the mug I noticed a seam in the middle that looks like two haves have been moulded to the outside of a mug base to create the smoothed surface area ........................ I wasn't sure if this would affect the pressing or not? (SEE IMAGE 4)
[ATTACH=CONFIG]318[/ATTACH]
Onto pressing and as there were quite a few posts regarding times and temps I thought I needed a starting point so I took this from Martin (at BMS) who had given the following times/temps - 125 degrees idle temp, 170 degrees operating temp, 90 seconds cooking time. Although there was no pressure guide I presumed that this would be medium?
[ATTACH=CONFIG]319[/ATTACH] [ATTACH=CONFIG]320[/ATTACH]
I created some colourful artwork so as I will predominantly be using these for kids mugs. The artwork I created had a small white border at the top and bottom of the mug (I would do a full top to bottom print later).
I placed the puck in the mug, then in the press and waited patiently. I don't know why but I had this horrible feeling that everything would melt in front of my eyes (just like the wicked witch when Dot threw some H2O on her) so the finish beep couldn't come quick enough!
I opened the press, took the puck out of the mug (yes - use gloves as it's hot!) and then ripped the paper off the mug. Usually I do this with bare fingers so I have grown quite accustomed to singing my finger tips ............... but the mug didn't seem that hot - and there was no "shushhhhhhhhh" and "hissssssssss" as the mug hits the (room temp) water (yes - I dunk!).
What I did (briefly) notice was the vibrant colour and what I thought was an excellent transfer of image to mug.
After a few seconds I took the mug out of the water, gave it a dry and a closer examination. The colours were magnificent and the transfer (ink to gas, to mug) had worked spot on. The join (between the two halves that I mentioned earlier) could not be seen at all.
BUT, I did notice that there was a little bit of plastic that had melted on the base of the mug and it looked like the mug press was a little too tight (sometimes you notice the pattern from the blanket on the mug and know it's too tight), but apart from that I was really, really pleased with the first attempt.
SO - SECOND ATTEMPT, and taking all above into account I decided to losen off the pressure a little and reduce the temp down to 160 (or it may have been 165, I will confirm tomorrow) and take the time right down to 60 seconds (30 seconds less).
THIS MUG WAS PERFECT IN EVERY WAY. There was no sign of melting, no signs of fadeness - all was fabulous!
[ATTACH=CONFIG]321[/ATTACH] [ATTACH=CONFIG]323[/ATTACH] [ATTACH=CONFIG]322[/ATTACH]
After pressing the second mug and realising that I could now get rid of the other four to people that had enquired about them in the last couple of days (I had initially written off 6 to get things right) - I then came up with a EUREKA MOMENT!
The thing is, these mugs are 100% polyester and unlike normal mugs that have the polyester coating on them all of the mug is subliminal. So, I thought - can I print on the inside of the mug?
I printed a design for the inside of the mug and another for the outside but that's when my EUREKA moment took a nose dive! Because the puck is very, very tight there is literally no room for anything .............. not even a sheet of paper! I tried both ways - placing the paper inside the mug and inserting the puck and wrapping the paper around the puck and inserting the whole thing into the mug but it wouldn't fit and would only go half way in (I told you that the puck was a tight fit). I didn't risk forcing the puck as if I did I might not be able to get it out again once cooked! I did have a feeling that the image wouldn't transfer to the inside properly anyway as the heat on the inside would be a lot less than the outside but I never got to test my theory!
So, all in all - mugs are great and image(s) to follow tomorrow! (EDIT: NOW ADDED ABOVE)
Adam
Adam
