Mug press issue
sapprinting
Re: Mug press issue
Post by sapprinting »
Good morning
I brought a mug press & I can't use mug press paper but I tried with t-shirt press paper and it works. Could Anyone Tell Me How To Do It With Mug Press Paper ? :confused:
Thanks very much for you help.
SAP
Andrew
Re: Mug press issue
Post by Andrew »
What paper are you trying to use as "mug press paper"? What happens when you try to print with it? The paper used in sublimation is just carrier paper and different ones give slightly different results but all should print on every item.
mrs maggot
Re: Mug press issue
Post by mrs maggot »
is it possible you are printing on the wrong side of the paper ?? some of the mug papers look almost identical on both sides
Re: Mug press issue
... Or whats wors iron transfer paper???
sapprinting
Re: Mug press issue
Good evening
I tried Premium Sublimation Paper for Mug Press and sublimation paper and when I printed with them nothing goes on the mug.
I tried the two side but it is still the same.
Then I tried with tee shirt heat press paper and it works even though its not for it.
sapprinting
Re: Mug press issue
Good evening
I tried both side but still the same.
accdave
Re: Mug press issue
Post by accdave »
I'm confused, have you got 1 paper for mugs and one paper for t-shirts.
Can we go back to basics, which paper did you get and where from ?
sapprinting
Re: Mug press issue
I got a mug press and a tee shirt press,Premium Sublimation Paper for Mug Press from Coralgraph and sublimation paper from lovecut.
John G
Re: Mug press issue
Post by John G »
You are using sublimation inks aren't you?
Andrew
Re: Mug press issue
Post by Andrew »
They aren't sublimation mugs then seems the obvious answer. Where did you get them from?
