Photo Mugs
Squadron Prints
Re: Photo Mugs
Post by Squadron Prints »
The reason I joined this forum was to get help! I am glad I did! I turn these our fairly quickly now with the most recent order being 100 mugs for RAF Lossiemouth!
Then a new print today with mugs too!
My problem was photmugs and the problems at the top and the bottom! The first mug I did today you can see at the top that there is not enough paper been taped to the mug - the rest are fine - the turning of the mug in the middle of the heat cycle did the trick so thank you for all your valuable advice - I am nearly there and patience is a virtue! My thanks to the many of you who post your hints!
Gill
AdamB
Re: Photo Mugs
Post by AdamB »
Very nice Gill, and some cracking artwork there ................ well done you (Adam give's Gill a cyber pat on the back).
Re: Photo Mugs
Great work Gill, always nice to follow someone's progress and you've nailed it ;-)
Kaz
Re: Photo Mugs
Post by Kaz »
Looking good Gill :-D
David B
Re: Photo Mugs
Post by David B »
They look fantastic, great well done. Good order
Squadron Prints
Re: Photo Mugs
Wouldn't say that I have nailed it yet but getting there - the thing is continuity and as I have so much other things to do sadly I don't have that! It has been a slow process with plenty gone in the bin but I have no regrets buying the machine and the help and encouragement from BMS and this board has kept me going! I spent hours reading the pitfalls and hints of others to learn and boy did it help! Thanks again! :-)
Re: Photo Mugs
Mugs look great. Good artwork really does make a pro product.
mrs maggot
Re: Photo Mugs
Post by mrs maggot »
Looking great, and you are getting in some good orders as well - another pat on the back for you
barryslip
Re: Photo Mugs
Post by barryslip »
Good stuff Gill! Which mug press did you go for? Mine (very old Chinese combi-press) is on it's last legs and cannot produce top-to-bottom images like that!
Andrew
Re: Photo Mugs
Post by Andrew »
Look good. A nice market for some decent orders if you have a regular way in as well.
