Printed transfer
Synapse Graphics
Re: Printed transfer
Post by Synapse Graphics »
Hi,
I am in need of 16 photos, about A5 size for some T-shirts we are quoting on.
Will need to go on a black T-shirt.
Thanks.
Dean.
These could be printed on sublimation flock, printable flex, OBM with colour laser or solvent printed. Are these going to be basically an A4 page sliced in half to give an A5 'slab' to be heat pressed or does it need a more intricate cut line around the image? I guess anyone here would need to know to get a quote.
Also StichUp on the forum does direct to garment printing and he could quote for 16 of these printed directly to black t-shirts if they were the same photo to each t-shirt.
Synapse Graphics
Good point, these will be just straight cut.
What ever is the cheapest, but reasonable quality, they are for a stag night.
chongsta
Post by chongsta »
not sure if im too late on this but ive sent you a PM ok.
The vinyl i use is directly printed and then you'll need some application film to lift it off the card, then press as normal.
cheers
Dave
