Squeaky Printer!
Discuss other print methods.
AdamB
Re: Squeaky Printer!
Post by AdamB »
Hi all,
My printer (the one that was sat in the attic for a couple of years before it was revived) is starting to squeak.
I am sure that it's the bar that the print head travels along - there is a kind of greasy substance on the on the other printers I have.
Does anyone know a quick fix?
Mugsman
Post by Mugsman »
try a bit of WD40 but when you spray it put a cloth under the bar so it doesnt go anywhere else
AdamB
Post by AdamB »
Mugsman;23201 wrote:try a bit of WD40 but when you spray it put a cloth under the bar so it doesnt go anywhere else
Wouldn't WD40 clean the carrier bar? I thought it needed some kind of lubrication?
Of course, I don't have a clue - hence the reason for sticking it on the forum although I 'do' really appreciate your help mate :-)
Lee
Post by Lee »
WD40 does stop things from squeaking though - i use it on hinges!
Kaz
Post by Kaz »
TPM;23203 wrote:WD40 does stop things from squeaking though
Would that work on the brakes on my car?
Only kidding!!
Lee
Post by Lee »
:biggrin: :biggrin:
AdamB;23192 wrote:Hi all,
You'll need some form of grease or silicon grease. Less is more here to avoid a build up of a mess a each end of the bar.
AdamB
Post by AdamB »
Thanks guys :-)
