bms plaques
Re: bms plaques
has any one got a template for bms plaques, in photo shop, at the moment i use a square with the outline of a shield and I use that, but I cant seem to center it when I press, Can anybody help. Thanking you you in advance
Re: bms plaques
Put the image face down on the plaque and you'll be able to just about see it though the paper to align it correctly.
dj_doubler
Re: bms plaques
jennywren;21968 wrote:has any one got a template for bms plaques, in photo shop, at the moment i use a square with the outline of a shield and I use that, but I cant seem to center it when I press, Can anybody help. Thanking you you in advance
Speak to AdamB he pressed a couple of slates not too long ago
http://www.dyesubforum.co.uk/vbforum/sh ... ion-slates
Anthony
Re: bms plaques
I've tried that but I can't see through it, the crest has to be dead centered with a scrollbms;21969 wrote:Put the image face down on the plaque and you'll be able to just about see it though the paper to align it correctly.
Re: bms plaques
dj_doubler;21971 wrote:Speak to AdamB he pressed a couple of slates not too long ago
Anthony
He did the slates
dj_doubler
Re: bms plaques
Try having a light shining either from behind or infront and you'll be able to line this up properly by sight.
Re: bms plaques
Guys - the easy way (providing you have a scanner) to create a template is to simply put it face down on a bit of paper and draw around it. Once drawn around scan at normal dpi (not to lose any size in proportion to the original image) - you then have an template for the item that you can use to make sure that any background overlaps to ensure that you get a full cover print.
If I'm teaching anyone to 'suck eggs' sorry ?
Re: bms plaques
Many thanks Adamb that's quite a good but simple idea , it would solve my problem, whats the normal dpi. I'll suck eggs any-day
