Page 1 of 2
Re: Looking for a few 'test' coasters to be printed
Posted: 04 May 2011, 20:00
As I've recently been testing different printers/profiles etc. I'm putting together a pile of coasters with identical images for further comparison.
I would very much like a couple printing from printers I don't have to see how these compare. I don't use the Ricoh range so it would be good to get some from the 3300 and also the 7000. Also, the B1100 and also the B42WD. If anyone is using the 4800 or larger format printers it would be good to see these as well.
It'll just be 2 coasters with different images but they must be on 90mm Circular Unisub coasters. I will gladly provide these (when I get around to ordering more in!) and also cover postage costs if needs be.
If you're confident that your system is printing to the best of its ability I'd appreciate your help.
[COLOR="red]edit: Just looking for the prints on Xpres paper so that I can print the coasters myself now :-)[/COLOR]
Posted: 04 May 2011, 20:25
by Paul
hmmm. i am not sure if my priner is printing his best but i may print some graphic on paper and then send you so you can press all coasters youself. this way save on postage and you know best what time and preasure you use for your coasters ;)
I can provide prints from B1100. just let me know what paper you want me t use.
Posted: 04 May 2011, 20:32
Actually that makes far more sense, I need everything else to be identical, press times/temp etc. so just need the prints then I guess :-)
It's a very interesting experiment, I'm aware of the limitations on colour matching/detail etc. with sublimation but tests so far have thrown up a few surprises.
Would need the prints on Xpres paper for continuity....did you get those I sent you Paul?
Posted: 04 May 2011, 20:37
by Paul
yep :) xpress paper is fab mate! I printed this test "dsf mug" with it. it stick a little to the coating but is nice stick if you know what I mean :) is like transfer pper sticked with that kind of spray you can buy to hold transfers :)
any way.... just send me a image and template of the coaster you want me to print and I will send you some.
Posted: 04 May 2011, 21:40
by smitch6
i have a B1100 justin if you want some from that
i only have trupix paper though
Posted: 04 May 2011, 21:45
by Kaz
Got a Ricoh 7000, but not the right kind of paper, if you want to send me a couple of sheets of paper, I'll gladly print some things for you
Posted: 04 May 2011, 21:48
by bms
The B42WD isn't supported yet so there won't be any takers for that one.
Posted: 04 May 2011, 22:12
smitch6;21767 wrote:i have a B1100 justin if you want some from that
Think I'm covered with the B1100 by Paul, thank you anyway :-)
Posted: 04 May 2011, 22:13
Kaz;21769 wrote:Got a Ricoh 7000, but not the right kind of paper, if you want to send me a couple of sheets of paper, I'll gladly print some things for you
PM me your address and I'll send a couple of sheets off, appreciate that. What software do you use?
Posted: 04 May 2011, 23:13
by Kaz
I've got a few to chose from, what's your preference? lol
