any one printed on 15oz El Grande??
Re: any one printed on 15oz El Grande??
hi. as in subiect. I wonder how they print and if they fit normal mug press ;)
Reg
Post by Reg »
Should be ok I do travel mugs which are the same dia.
Andrew
Post by Andrew »
As long as you can slacken the element off a small bit you will be fine. It's a nice mug to add to the range for anyone already printing mugs. Prints much the same.... might need an extra 20 secs due to being a bit thicker.
jennywren
Post by jennywren »
I always thought for some reason that you had to have different press for different size mugs. Which mugs would fit a Geo knight,
Andrew
Post by Andrew »
It tends to be trial and error for different presses/mugs. Just need to hope someone else does the trial bit first and tells you what will fit. Basically, if you can have your press so that a 10/11oz mug is loose inside then a stein will probably fit. The smaller mugs you would need a different element to swap.
JSR
Post by JSR »
I can't fit El Grande mugs in my mug press (although I could just fit the previous version of the BMS stein). Even when using mug wraps, I have to back them off all the way - so much so that I take the screws out. So don't assume that an El Grande will fit in your mug press.
:( thank you all! I think I will order 6 first from martin and see how it goes.
JSR
Post by JSR »
Paul;21777 wrote::( thank you all! I think I will order 6 first from martin and see how it goes.
I'll be interested to know if they're any straighter these days.
We have prints full top to bottom on the El-grande. It's Scotts mug of choice for his cuppa!
what press did you use for full wrap martin?
