One mug after another in a press
mgibbs
Re: One mug after another in a press
Post by mgibbs »
Hi
When using a mug press (DF1 in my case) should you let the temperaure drop below the sublimation activation temperature before putting the next mug in so you get consistant times or is it not that critical?
Mark
On that mug press it isnt that critical. The time won't start until it reaches operating temp.
mgibbs
Post by mgibbs »
Thanks Martin
Mark
