hi there
i have an epson s21 with ciss system and sub ink, been printing ok but for some reason when i go check my settings before i print just to make sure they are right when i press ok the dialouge box on the right hand side changes itself from printer manages color to photoshop manages color, i have cs5 on my netbook and checked the settings there and at the top of the print page where the color management is and just below where it says document, under document it says profile adobe rgb (1998) on my other machine that i use it says under document srgb iec61966-2.1 i have not got a clue how that setting got there, what should the settings be for this any help would be greatly appreciated as i have an order of 50 mugs to do.
malcolm
printer set up
Re: printer set up
Have a read of this document...
http://sawgrasseurope.indigofiles.com/technical_support/artainium/graphics/windows/b1100/Photoshop_CS5_B1100.pdf
