hotflex
smitch6
Re: hotflex
Post by smitch6 »
HI :)
i have just taken delivery of my robo cutter :)
so apologies as no doubt i will be asking lots of questions now from all you ppl who have one lol
i will however search before asking but apologise again if i can't find the answer but it's already posted
anyway there is some hot flex sheets with it
what depth of cutter should i use?
1 side is shiny the other is dull
do i cut on the shiny or dull side? mirrored or normal?
and then which way do i press it?
do i need to put it thru the robo with a carrier sheet? or not?
also i have some sign vinyl here what about that because that has a paper backing
thanks steve
mrs maggot
Re: hotflex
Post by mrs maggot »
smitch6
Re: hotflex
Post by smitch6 »
Thanks for that Mrs i thought i remembered seeing info somewhere but the title wasn't a help lol
i've done a little cut of some text just got to figure out how to cut round a shape now :)
well impressed so far
i did notice that the carrier sheet makes and if you back the cutter off a touch it doesn't always cut through the paper (i'm testing it on normal paper)
the flex do you have to use it with a carrier sheet?
Re: hotflex
no carrier sheet for flex or flock. but definytly yes for normal paper ;)
bikertec
Re: hotflex
Post by bikertec »
I can see you having more fun now. Don't forget the tissues when you see the waste you get your going to be in tears.;)
Ride it like you stole it shiny side up.
