Winpcsign 2010
Re: Winpcsign 2010
Hi
Does any one know where I can but winpcsign 2010 or strass rhinestone creative software or any other rhinestone sftware which will work with a Craft Robo. The only software I can find is from Canada and the shipping is expensive, so if anyone know where it can be bought in the UK i'd be grateful to know.
Thanks Bob
Thanks Bob
Re: Winpcsign 2010
I dont think you find all those software will work with CR as is all about drivers. they may not suport such a small cutter. but I may be wrong.
You can use THIS software for your rhinestone designes. Trick is that you can design your rhinestone art then export it to EPS and cut it from any cutting software.
quite powerfull software. I am useing it myself and iam happy with it. here you can watch some video what thissoft can do.
Re: Winpcsign 2010
I don't think the CR has sufficient downforce to cut the sandblast vinyl.
Re: Winpcsign 2010
true. my cutter can force up to 500. what about cr?
Re: Winpcsign 2010
It gives a list of drivers that come with it and the Craft Robo is one of them, it show rhinstone templates beig made on the Craft Robo. Can I ask where did you buy your Funtime 2010 Paul, it would be just as good if even if I had to export my designs to the craft robo the only worry I would have is that the craft robo can be a bit tricky to export to as I've tried exporting a lot of files to it with no success.
Re: Winpcsign 2010
There is a new Rhinestone starter kit available for the Craft ROBO. Don't know how this material compares to sandblast vinyl though.Stitch Up;18400 wrote:I don't think the CR has sufficient downforce to cut the sandblast vinyl.
http://www.graphtecgb.com/craftrobo/med ... r-kit.html
Re: Winpcsign 2010
I bought my funtime from here http://funtimescrapbooking.com/Software ... tones.aspx
Re: Winpcsign 2010
Thanks Paul
Do you know if I can use this software with the craft robo
Re: Winpcsign 2010
no. You can not cut via this software. You can only design your rhinestone templates then export them to vector file. Then cut it in any cutting software like flexi, artcut, easycut, corel (with craftrobo plug in), illustrator (with cr plug in) etc...
Re: Winpcsign 2010
Hi Paul
PM'd you
PM'd you
