B1100 Problem's again :(
busybusybee
Re: B1100 Problem's again :(
Post by busybusybee »
Hiya, i had a issue with "splattering" which BMS were brilliant and helped me sort with the aid of a new cart/tube assembly. This worked and has worked fine, there was air in the lines and BMS said this would sort itself out in time, which it appeared to be doing, i went to it tonight to do a few mug's (have been using it regular) and it started printing lines in the colour, so i did a head clean, now the ink's running backwards and forward's in the line and the inks are missing on test colour's and i cant get a nozzle check to print.
I will give BMS a ring in the morning (probably sick of hearing from me) but in the meantime any advice would be great??
Cheer's :(
Am gutted as the quality of the print was amazing aswell!
busybusybee
Thank's BMS, i will reprime soon but this morning i tried printing and im getting better quality, not perfect but better, so i will keep trying. Thank's for your great help as always!
