Stainless Travel Mugs
Re: Stainless Travel Mugs
I just recently bought some stainless travel mugs with a 3x8 white sublimatable panel on it. I have a full coverage design I want to put in that space but am worried about not aligning the paper perfectly and having some white showing. How much bigger than the white space should my design be and is there any problem with sub dye on the non-sub part of the mug?
OK, got my answer from Conde. Image should be .125" larger than the white panel. only the white panel is sublimatable so there shouldn't be any issue with the larger image onto the stainless.
