4 in 1 heat press
mrs maggot
Re: 4 in 1 heat press
Post by mrs maggot »
I have a chinese in origin heat press, with the plate / cap and mug press attachments, it works fine, and i mainly use it as a back up press for t shirts, when i have big orders in, I thought it would be helpful to buy it as a combi press, but now have invested in a separate mug press & cap press so it is surplus to needs. i have also just bought another heat press, so this one needs to go, i can organise photos etc if you need them, i guess collection in an ideal world would be best as they are heavy/delicate and i could then show it all working, but delivery could be arranged.
same as item 350443461168 on ebay at the moment, only a bit more used i would think than that one, i have put foam round the handle, as i found it too uncomfortable without. the part where the lead goes into the machine, i have had to hold up with a cable tie, as i find it drags and can catch in what you are doing. £130.00 postage i would put at around £15 by courier
