Acetate Mug Boxes
- Has thanked: 11 times
- Been thanked: 9 times
Re: Acetate Mug Boxes
Bought a load of acetate mug boxes off eBay a while back and they were really good, perfect size for 10oz mugs. Came to re-order and supplier didn't have any so I bought the BMS ones. These are better because they are thicker but are taller and a 10oz mug rattles around a little unless left in the bubble wrap.
Does anyone have a source for the smaller/thinner acetate boxes?
Transfer Press do the thinner ones, perfectfit. Got to admit I don't like the thicker onesJustin;17627 wrote:Bought a load of acetate mug boxes off eBay a while back and they were really good, perfect size for 10oz mugs. Came to re-order and supplier didn't have any so I bought the BMS ones. These are better because they are thicker but are taller and a 10oz mug rattles around a little unless left in the bubble wrap.
Just looking on their site, I did wonder if they were the smaller ones, description seemed to back it up but no piccy. Many thanks
I have some if you ever need them and can't find them elsewhere. Tight fit for the 10oz so keeps everything in place.
Also a lot easier to assemble too.Andrew;17658 wrote:I have some if you ever need them and can't find them elsewhere. Tight fit for the 10oz so keeps everything in place.
You can get from a company called Norfolk china, I use them to put in mugs when I sell them but don't use them for posting. They are on suitable for a 10oz. Hope this helps
Just check their website it's under construction but you can phone them that's all i do
There's a few different versions out there and I did find an easier one to put together but was about 10p more. Thought I would just suffer with an extra 2 seconds work for that cost. It did work well though as you could just pull the 2 flattened sides apart and the base automatically locked in place. Mine you have to fold the base in after pulling sides apart. Surprising how many designs there are out there.accdave;17660 wrote:Also a lot easier to assemble too.
Talking of box designs, have you ever seen the retail cardboard mug boxes where the mug is fully visible in the frontand locked in by just the handle. This box also converts into a real enclosed box as well. Great design. Having some priced up now.
the bms ones are great for adding a coaster in with them
Hi Justin. Did I manage to reply to the PM's you sent? After I send them they don't seem to show in my sent folder.
Thanks,
Andrew
Thanks,
Andrew
