Does anyone use syncthemcalendars to manage their sublimation orders?
Coney
Post by Coney »
Hey, I’m losing track of everything. I have three regular clients who order batches of sublimation mugs and T-shirts from me, each with their own delivery deadlines and design approval windows… and I’m managing all of this with Post-its and a homemade Google Calendar. Two weeks ago, I missed a confirmation deadline because I hadn’t synced my personal calendar with my work calendar as a result, the client had to follow up twice, which was awkward. So I started looking for calendar sync tools, came across Syncthemcalendars, and it seems to do the job of automatically linking multiple calendars. But seriously, has anyone here tested it in a production environment… like for drying, transfer, or cutting schedules? I don’t want to dive into this if it’s complicated to set up for such specific tasks.
GoldRapt
Has thanked: 6 times
Been thanked: 8 times
Re: Does anyone use syncthemcalendars to manage their sublimation orders?
Post by GoldRapt »
I found your question interesting but no nothing about that software, so I posted the question in claude and it said this----Good question to dig into, and worth separating two different problems that are getting merged in that forum post.
**What SyncThemCalendars actually does**
It's a real tool — it copies events between Google/Outlook/iCloud calendars (one-way or two-way), so a "busy" block created in your personal calendar mirrors into your work calendar and vice versa. That's genuinely what would have prevented the exact mistake described: a personal-calendar clash silently colliding with a work deadline because the two calendars never talked to each other. Its core pitch is set-and-forget syncing between Google, Outlook, and iCloud, filling the gap of copying events between calendars that Google Calendar itself doesn't do. Setup is genuinely quick — connect accounts, pick source and target calendars, and the sync is created — and it syncs in real time so changes show up immediately rather than requiring manual re-syncing.
Worth flagging: a chunk of what's floating around online about this tool (the "Top 5" roundup, some of the review-site copy) reads like marketing content rather than independent testing, so treat the glowing quotes with a pinch of salt rather than as verified production performance.
**But it's not built for what you actually need**
Syncing "personal vs work calendar" solves double-booking. It does nothing for the harder problem you're describing — design approval windows, drying times, transfer press queues, cutting schedules for three different clients. Those aren't single events, they're **dependent stages**: approval → print → press → cure/dry → ship, each with its own lead time, and if one slips the whole chain shifts. A calendar sync tool has no concept of "this step can't start until that step finishes" — it just copies blocks.
For that, you want one of two approaches:
1. **A single production calendar with structure, not two calendars merged.** One calendar (Google is fine), color-coded per client, with each job entered as a *series* of events (approval deadline → press slot → dry/cure buffer → ship date) rather than one entry. This is basically free and solves the "I forgot to check my other calendar" problem without adding a third tool.
2. **A lightweight task/kanban tool** (Trello, Notion, or even a simple spreadsheet) where each job is a card that moves through stages — Awaiting Approval → Printing → Pressing → Curing → Ready to Ship — with a due date per stage. This is what actually prevents missed confirmation deadlines, because the deadline lives attached to the job, not floating in a calendar you might not open that day.
Calendar sync is a nice add-on once you've fixed the structural problem (personal and work calendar not talking), but it won't fix the root cause in the post — which sounds more like "no visibility into job stages" than "two calendars out of sync." If you want, I can sketch a simple client-job tracker template (spreadsheet or Trello board) built around approval → production → dry/cure → ship stages.------Not sure if that helps but it gets the ball rolling.
regards
Tony
-launching july/august 2026
