Sold Stahls Hotronix Maxx Clam 28x38cm Heat Press - Free UK Delivery
msub
Post by msub »
£199.99 Free UK Delivery.
Quality heat press which has rarely been used so in excellent condition and works perfectly.
Only been used with Quick Slip Platen Protector (included).
Specification:
  • 28cm x 38cm platen
    Digital LED display to adjust time and temperature settings easily.
    Temperature range from 96°C (205°F) to 220°C (430°F)
    Easy to operate, with minimal knowledge required.
    Space-saving clam heat press design.
    Over-The-Centre pressure adjustment for even pressure.
    HRPO laser-cut steel framework.
    Powdered coating for scratch-resistant finish to framework.
    ¾” thick non-stick coated upper heat press plate.
    Dampers rather than springs for easier and smoother opening and closing.
