Printing on Oracal 6510
MP21
Re: Printing on Oracal 6510
Post by MP21 »
Hi all,
I'm a complete newbie to all this and my aim is to print black text on the fluorescent Oracal 6510 vinyl for outdoor use. I need to achieve this as cheaply as possibly. From my limited research up to this point, would this be possible by using a cheapish Epson EcoTank with eco-solvent ink? If so, what kind of results would it give?
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
You can’t print ecosolvent ink with an ecotank. (At least not as far as I know)
you will need a ecosolvent printer like a Roland or similar.
If you plan on using it outdoors long term you will also need to laminate the print.
MP21
Post by MP21 »
Mrteajunkie;152794 wrote:You can’t print ecosolvent ink with an ecotank. (At least not as far as I know)
Hi mate, thanks for taking time out to reply. There's quite a few videos on YouTube where they convert the EcoTank just by using eco-solvent ink (this does void the warranty though)
https://www.youtube.com/results?search_ ... co+solvent
As for the life of the print, I'm only looking for 18-24 months.
Mrteajunkie
Well There you go I never knew that.
I wouldn’t say that’s ecosolvent printing the product videos look awful.
18-24 months is what I would call long term so laminating would need to be done.
pw66
Post by pw66 »
From what I understand printheads don't last very long when you convert a small Epson to eco solvent. It is possible to do but the heads are designed for water based inks.
Mrteajunkie
I wouldn’t fancy changing an epson printhead.
Are they even removable?
canon are great just remove inks and lift the bar and out it pops.
I have rescued a few canon heads by soaking them in ipa.
MP21
Post by MP21 »
Thanks for the replies again. If this doesn't seem great option then what would be a good way of doing it do you think. I don't mind spending a few hundred pounds. All I want to do is print on something say 130mm squares and it last 18 months or so outdoors
