Roland VS-300
Re: Roland VS-300
Hi All
Anyone want a spares or repair Roland VS300 wide format printer before I put it on ebay?
Ideal "project" for someone who likes a dabble. Print head has gone and as it has been sat for a while it will most likely need the tubes, capping station etc etc as well. An enginner quoted 3.5-4k to fix so its not worth paying for it to be fixed. But it will be worth it for someone who is good with this sort of stuff.
Machine is configured CMYKLcLm WHITE and Metallic. I am pretty sure you can not reconfigure the machine from this but if you do not use White or Metallic then you can always use flush fluid instead.
First £100 takes it. Item is based in Rhuddlan (N. Wales)
Really want it gone ASAP as have too many machines here and not enough room :-)
Will even supply the computer with Versaworks Rip on it to print from (quite an old version but it works).
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Re: Roland VS-300
Post by Mrteajunkie »
I would have taken a punt on this myself for £100 but then I Googled where you are !!!
that would be a long trek for me lol
pw66
Re: Roland VS-300
Post by pw66 »
Worth buying for anybody considering a spurious liquidation. No point leaving the Official Receiver working equipment.
Re: Roland VS-300
Or someone who is going to have a break in within the next 6 months ;-)
