Page 1 of 2
Re: How to dispose of defective sublimated items with photos?
Posted: 31 Dec 2022, 18:41
by Sublibed
Hi, hope all's well. Ater some advice, I make personalised photo gifts with sublimation (mugs etc as well as flat products). If something goes wrong and you have to dispose the item (with someone's photo), how do you get rid of them?
Not keen to put them in the bin as we've had people snooping through our bins in the past.
Cheers
Posted: 03 Jan 2023, 14:27
by socialgiraffe
We have the same but for officially licensed products. We always smash the items to make them completely useless before putting in waste.
Posted: 03 Jan 2023, 22:55
by pcwizme
depends on the item. glass coasters I sandblast the back off, then I sandblast a pattern on the front. Mugs I just sandblast the coating off (with a soft grit) which sometimes leaves a pretty normal mug
Posted: 04 Jan 2023, 21:58
by Sublibed
Thank you both for your replies, appreciated! Will smash the items. Cheers!
Posted: 11 Jan 2023, 19:59
by GoonerGary
Sublibed;151858 wrote:Thank you both for your replies, appreciated! Will smash the items. Cheers!
Or the safer approach would be to put them back in the heat press or oven and cook them until they go very blurred.
Posted: 12 Jan 2023, 01:18
by pisquee
You can print solid black over them
Posted: 12 Jan 2023, 14:51
by Andrew
We reclaim ours then re-use the mugs..... just need sufficient temp to do this.
Posted: 13 Jan 2023, 02:11
by pisquee
Reclaim? What do you mean?
Posted: 13 Jan 2023, 08:29
by Andrew
pisquee;151888 wrote:Reclaim? What do you mean?
You can fully remove the print by high firing then screen print or water slide the mug.
Posted: 13 Jan 2023, 09:46
by pisquee
Firing ... like in a kiln? Tell me more!
