How to dispose of defective sublimated items with photos?
Sublibed
Re: How to dispose of defective sublimated items with photos?
Post by Sublibed »
Hi, hope all's well. Ater some advice, I make personalised photo gifts with sublimation (mugs etc as well as flat products). If something goes wrong and you have to dispose the item (with someone's photo), how do you get rid of them?
Not keen to put them in the bin as we've had people snooping through our bins in the past.
Cheers
We have the same but for officially licensed products. We always smash the items to make them completely useless before putting in waste.
pcwizme
Post by pcwizme »
depends on the item. glass coasters I sandblast the back off, then I sandblast a pattern on the front. Mugs I just sandblast the coating off (with a soft grit) which sometimes leaves a pretty normal mug
Sublibed
Post by Sublibed »
Thank you both for your replies, appreciated! Will smash the items. Cheers!
Post by GoonerGary »
Sublibed;151858 wrote:Thank you both for your replies, appreciated! Will smash the items. Cheers!
Or the safer approach would be to put them back in the heat press or oven and cook them until they go very blurred.
You can print solid black over them
Andrew
Post by Andrew »
We reclaim ours then re-use the mugs..... just need sufficient temp to do this.
Reclaim? What do you mean?
Andrew
Post by Andrew »
pisquee;151888 wrote:Reclaim? What do you mean?
You can fully remove the print by high firing then screen print or water slide the mug.
Firing ... like in a kiln? Tell me more!
