Just a quick one, where is everyone sourcing their heat tape from that you would recommend, we currently have a supplier that is just over 1cm in thickness which is great for our mugs but recently finding them unstick after a certain amount of time. We need a tape that can be stuck on a Friday, with the mugs holding until Monday or Tuesday. If anyone has any recommendations we would most welcome
Best Heat Tape For Mugs
bubbleimages
Re: Best Heat Tape For Mugs
Hi all,
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
I use either the tape from inkexperts or mdp.
but the mdp tape doesn’t fit my dispenser
I've just bought 5 rolls of blue MDP tape. It bloomin' stains the mugs! My recommendation is for the blue tape from Neil Brothers or Subliblanks. Xpres tape is ok, but a little hard to cut, it's clear and expensive.Mrteajunkie;151065 wrote:I use either the tape from inkexperts or mdp.
Another vote for Inkexperts tape. No staining, sticks well, not expensive, although I've not tried it over 4 daysMrteajunkie;151065 wrote:I use either the tape from inkexperts or mdp.
- Mrteajunkie
I would be emailing them about that!GoonerGary;153131 wrote:I've just bought 5 rolls of blue MDP tape. It bloomin' stains the mugs! My recommendation is for the blue tape from Neil Brothers or Subliblanks. Xpres tape is ok, but a little hard to cut, it's clear and expensive.
take pics and send them over they will sort it for you.
I switched to just using ink experts tape.
I have two rolls on my dispenser at a time so it cuts it into strips perfectly one click is enough for one mug or one coaster.
Best tape - clear! no marks.
