Xpres enamel mugs
Re: Xpres enamel mugs
Post by GoonerGary »
Did Xpres change their enamel mug coating to Orca recently? Their old coating had a warmer white colour and felt thicker and smoother.
The Orcas are much whiter, but have been suffering from hundreds of dimples all across the coating for the last several months.
[MENTION=1]Justin[/MENTION] Could you update the Xpres April code? Need to try and get an order in for Monday, thanks.
Apologies, all now updated :-)
Saying that the code could not be applied to the enamel mug order.
Stranger they should be discounted, I'll have to check with Xpres.
Xpres haven't updated system to use new April code I believe as cannot order anything using it. VERY annoying.
