Hi All, I attempted to start a Street-Wear Clothing business in 2019, but regrettably it didn't work out (hindsight is a beautiful thing as they say), and I have been keeping the following equipment in storage since.
All items are in very good condition with minimal use, and are available for pick-up only (I'm in Northfield, West Midlands)).
I also work from home, so have some flexibility in terms of potential viewings during the day (as well as evenings and weekends too)
Therefore, please confirm the date and time you plan to come prior.
PLEASE NOTE: All items will be `sold as seen`, therefore when you view, please ensure you are 100% satisfied before purchasing, as you will have the opportunity to view and test the items.
Ball Heat Press with Auto Open and adjustable base, LCD Screen
Price Selling: £95
Features
-LCD Digital controller - Individually controlled time and temperature.
-Thick heating plates - Make sure high pressure for work.
-Strong metal structure - Machine is heavy-duty, commercial-grade, and super stable.
-Pneumatic elevating system - Maintain an even and high pressure.
-Auto Open
-Adjustable height ball base support
-Top Platen Size: 12x12cm
-Weight: 17kg aprox
-Power cable included
Note: manual not included, but easy to use. Good used condition (hardly used), local pickup only
[ATTACH=CONFIG]6848[/ATTACH][ATTACH=CONFIG]6849[/ATTACH][ATTACH=CONFIG]6850[/ATTACH][ATTACH=CONFIG]6851[/ATTACH][ATTACH=CONFIG]6852[/ATTACH]
Any questions or queries, please let me know
Juggy aka Rishi
Swing Heat Press, 28" Plotter/Cutter and Ball Heat Press
juggysingh
Re: Swing Heat Press, 28" Plotter/Cutter and Ball Heat Press
- vB_ID:6858
- 20220219_210524.jpg (86.77 KiB) Viewed 139 times
- vB_ID:6857
- 20220219_210454.jpg (97.17 KiB) Viewed 139 times
- vB_ID:6856
- 20220219_210448.jpg (96.74 KiB) Viewed 139 times
- vB_ID:6855
- 20220219_210439.jpg (90.31 KiB) Viewed 139 times
- vB_ID:6854
- 20220219_210435.jpg (93.08 KiB) Viewed 139 times
- vB_ID:6853
- 20220219_210430.jpg (97.76 KiB) Viewed 139 times
- vB_ID:6852
- 20220219_215721.jpg (89.59 KiB) Viewed 139 times
- vB_ID:6851
- 20220219_204122.jpg (95.54 KiB) Viewed 139 times
- vB_ID:6850
- 20220219_204113.jpg (97.59 KiB) Viewed 139 times
- vB_ID:6849
- 20220219_204036.jpg (88.32 KiB) Viewed 139 times
- vB_ID:6848
- 20220219_204026.jpg (92.88 KiB) Viewed 139 times
