pneumatic heat press pressure setting
DanEC33
Re: pneumatic heat press pressure setting
Post by DanEC33 »
Hi,
I have bought a pneumatic heat press for sublimation printing but I am a little confused regarding the pressure setting. The mat I am trying to sublimate states that I should use 5 bar pressure but my press range is from 0 to 1 so in my case is 0.5 equal to 5 bar pressure – any clarification on this would be great.
Thanks!
GerryG
Post by GerryG »
Hi,
Could you state which pneumatic heat press you purchased, maybe then someone on here can help you out.
logobear
Post by logobear »
there will be a pressure guage that gives the actual pressure, - the pressure knob is just a relative up/down valve.
5 bar is a lot for sublimation, - normally only need enough to stop any movement .....
