Sparta Mug Print query!
Martinx
Re: Sparta Mug Print query!
Post by Martinx »
Hi there
I am keen to print on Sparta Mugs but because of the raised lip can this cause damage to the Mug press blanket? or do I need to make sure the lip of the mug is poking out one end of the unit?
Martin
JSR
Post by JSR »
Just make sure the raised lip is poking out one end of the blanket.
If using an oven, I use a piece of silicon rubber to go around the mug and that allows me to put the mug in the adjustable wrap without worrying about it sticking out the end.
