Hi everyone,
I am trying to print on double sided MDF and FRP using the 3M spray. No matter how light or far away I spray it, the finish is always mottled. I always clean the nozzle after each use too. Has anyone got any tips on double sided products as I have a customer wanting 150 keyrings.
Thank you in advance
Double sided/spray adhesive
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
Re: Double sided/spray adhesive
Keyrings have to be taped in my experience.
It’s a pain but it’s the only way as spray adhesive will just ruin the print.
3M 75 spray only really good for fabrics, hard surfaces best using heat tape
Thank you both for your replies. I’m finding that the tape is lifting the print from the first side
- Mrteajunkie
if the print is lifting you have a very poor product.Bex;148897 wrote:Thank you both for your replies. I’m finding that the tape is lifting the print from the first side
