Re: Coasters in ovem
Posted: 02 Apr 2021, 11:35
by Robbiejd
Is it possible to sublimate coasters or flat objects in an oven?
Or do you need a heatpress?
Posted: 02 Apr 2021, 13:54
by Mrteajunkie
I wouldn’t try it myself.
you need the pressure on the paper to transfer the image but I may be wrong as I have never tried it.
Posted: 02 Apr 2021, 14:15
by GoonerGary
Only in a 3D vacuum press oven I would guess. But why bother when flat heat presses are cheap and work perfectly? Ready in 60 seconds!
Posted: 02 Apr 2021, 17:39
by socialgiraffe
You could probably use heat shrink, but like others have said, why bother when a cheap heat press will do the job easier and quicker...
Posted: 02 Apr 2021, 21:30
by Robbiejd
Thanks everyone
I was just thinking of space and what equipment I need .
Thanks again
Posted: 02 Apr 2021, 21:57
by Paul
They will warp.
Posted: 03 Apr 2021, 13:00
by socialgiraffe
They will warp.
Good point
