Problems printing on 3mm Cast Acrylic
alarholm
Re: Problems printing on 3mm Cast Acrylic
Post by alarholm »
Hi
hoping someone can help me?
ive been trying to sublimate on clear cast acrylic and it’s doing really nicely BUT, I just can’t get it fully transparent again without it looking dirty on the printed side. I’ve tried scrubbing it with non abrasive sponges, I’ve tried a magic sponge but all still leave it cloudy.
looks stunning while water is flowing over it, but the minute it’s dry and you’re looking close up, it’s a problem. Please help! How do we get it back to fully transparent again?
Here’s a sample...[ATTACH=CONFIG]6583[/ATTACH]
thanks so much!
Aly
vB_ID:6583
vB_ID:6583
ICF
Post by ICF »
Are you using a silicone sponge between the paper and the heat press?
It could be the texture of the press indenting on the acrylic when it softens.
Andrew
Post by Andrew »
What time and temp? 3mm will struggle under a lot of heat. Have you trialed the lesser heat and time options?
froggy
Has thanked: 1 time
Been thanked: 2 times
Post by froggy »
If acrylic gets too hot it will "bloom" Too high a temperature would be my guess.
