Print and cut text help.
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Re: Print and cut text help.
Post by Mrteajunkie »
I’m useless with illustrator so I need help.
I want to create some text in different colours and cut it out for a T-shirt.
when I select the text to create the cut line like I do with images the centre of the letters becomes filled leaving a white area.
How can I create a cut line for 3 lines of text but have them cut out the centre of the D, O, P and B for example instead of it becoming a solid image?
Mrteajunkie
By sheer coincidence this has come up on YouTube :biggrin:
https://youtu.be/GVFJ-bk--4w
Is google watching me?
Now I feel thick it was as simple as creating a 0.25 stroke in magenta without combining the text.
razerphotographic
Post by razerphotographic »
Probably late now but if i understand you right this is how i do it....
creat your text to size you want - id duplicate it now in case need to make changes as going forward wont be re editable.
go to object - expand - expand both fill and stroke.
ungroup
then use pathfinder to divide it all up into sections. Delete the centres of any letters needed.
my cut software whilst will open/ import ai files, any text mot expanded it wont pick up as wont cut straight from the text/ font format.
thats how i deal with fonts/ lettering. Gives you a scaleable version then as converts to vectors! ��
