Dense Black printing issues
Martinx
Re: Dense Black printing issues
Post by Martinx »
Hi
I am having problems printing a dense black on the Xpress transfer paper I am using. The inks are artainium and printing using Epson S21. The print looks more a black with a blueish tinge.
I am using Indesign on a mac and just wondered if the black should be made out of CMYK, RGB?
Also when pressing a black print to a mug should I lower the press time?
Currently temp 180 at 180sec.
Martin
Has thanked: 11 times
Hi Martin, are you pressing the image or just looking at it on the paper? Can you check the composition of the black to make sure it is 100% black and not a combination of colours?
Martinx
Post by Martinx »
Hi Justin
Just pressed it on a mug and seems ok. I was just looking at the print on the paper! I tried C:20 M:20 Y:20 K:100 and 100% black but both looked the same. Weird.
I would go for 100% CMYK for the deepest black colour.
