sticker paper/masking
Discuss other print methods.
rossikey
Re: sticker paper/masking
Post by rossikey »
I don't know if anyone can help me here....I am after some sticker paper that i can use for masking too....
So i can stick it on to something...paint over it and then peel it off......so ideally covered with a sheet of application tape,
would ideally be using it with robo craft
can anyone help ...if i can get some it would be fantastic
Reg
Post by Reg »
Most vinyl suppliers do a masking vinyl you'll have to put your own application tape on after cutting and weeding I use star vinyl's or victory designs their names are the same as their websites.
AdamB
Post by AdamB »
I use the below when I do the odd sign etc.
http://www.mdpsupplies.co.uk/clearappli ... etotal.asp
And it's quite thick so I reckon you could stick to the carrier sheet and then cut it .................... ?
rossikey
Post by rossikey »
Thank you ..i will look at both of them....
rossikey
Post by rossikey »
I dont think they will work...i have put a link here to what i want to do....give you some idea...
hope the link works...if not item number 120671335618 on ebay....
mrs maggot
Post by mrs maggot »
blimey i thought they were cheap - then i saw they were for model cars :)
fredster
Post by fredster »
you used to be able to buy this sort of stuff from good hobby shops...its used for airbrushing stuff ... i remember using it years ago with some great results.it came on a roll like cling film .. try looking at art stores
