Design and Print Templates
Any OS, software in here.
mnporter2001
Re: Design and Print Templates
Post by mnporter2001 »
So mugs are fairly easy to design and print but I am having issues with these damn phone cases.
Is there some software similar to SubliRip that has the blanks re loaded so you just add your design/text and print ?
Currently I am having to try and find the correct size image template on google load it on to Paint Shop Pro add my image and text and then keep my figures crossed I have it sized correctly.
There must be a library some where with these ?
Many Thanks
Mark
Custom Gifts www.mugsaway.co.uk <--- A work in progress!
The main stumbling block here is Paint Shop Pro. If you used Photoshop instead you could use Smart Objects and then all you'd need to do would be to change the image and text in the Smart Object layer, press Ctrl+S to Save, and your template will be updated.
Templates can be easily made by scanning a blank and sizing it in Photoshop. No need to rely on Google.
