RESOLVED, NO HELP NEEDED NOW: I could really use some help if anybody is able to advise.
Using Epson ET7750 printer. Ok, so my issue is this... When I print a file directly from Affinity, the colours come out wrong - pinks are more orange / brown etc - see top print in the image attached. This has only just started happening in the past 2 weeks or so. However, when I export the file as a PNG, then reopen in affinity and print, the colours are coming out normal - pink is pink (see bottom print in the image). I've attached pics of my settings for both. This is happening in Affinity Designer. I do have Affinity Photo too and the same thing is happening.
Anyone able to shed any light as to why its doing this or what settings I need to change?
[ATTACH=CONFIG]6349[/ATTACH][ATTACH=CONFIG]6350[/ATTACH][ATTACH=CONFIG]6351[/ATTACH]
Colour Changes Printing AFDesign and PNG Files
Re: Colour Changes Printing AFDesign and PNG Files
- vB_ID:6351
- Slide2.jpg (12.86 KiB) Viewed 9 times
- vB_ID:6350
- Slide1.jpg (12.54 KiB) Viewed 9 times
- vB_ID:6349
- Affinity File Comparison.jpg (78.47 KiB) Viewed 9 times
