Re: Graphtec CE6000plus and Coreldraw2020
Posted: 28 Aug 2020, 15:08
by windyash
Is anyone using a GRaphtec CE6000plus and the latest Coreldraw? Just purchased an unused Ce6000plus cutter but cant get it to work with my Coreldraw 2020
Everytime I try and cut I get an error message
Running Coreldraw not Found
Can anyone help?
Posted: 29 Aug 2020, 07:29
by StellaD
You will need to download Cutting Master from Graphtec..
It is a free plugin which installs in CorelDraw and lets you cut direct (also works in Illustrator)
Make sure you have the full version of Corel though as I don't think it works with the cut price student edition.
Posted: 29 Aug 2020, 19:48
by Mrteajunkie
Ditch Corel and go with sure cuts a lot pro.
So much better and easier to use.
Posted: 31 Aug 2020, 07:33
by webtrekker
Mrteajunkie;144737 wrote:Ditch Corel and go with sure cuts a lot pro.
I'm with Mr T on that. I've used it for well over 5 years now for all of my cutting.
Posted: 03 Sep 2020, 16:12
by Quinsfan
Why ditch corel if that is what the OP has always worked with? They may use it for other work not just to cut stuff, not a really helpful answer. I have an old Graphtec 7500 that is connected to an old XP laptop, which is not connected to the internet, but to my network, that I use for cutting my garment vinyl. This is because I have a workshop and studio. I can open the file on the XP laptop in an old version of coreldraw and then use cutting master 2 to cut the file.
Or as the second poster says try the Cutting Master download and see if that connects.
