Graphtec CE6000plus and Coreldraw2020
windyash
Re: Graphtec CE6000plus and Coreldraw2020
Post by windyash »
Is anyone using a GRaphtec CE6000plus and the latest Coreldraw? Just purchased an unused Ce6000plus cutter but cant get it to work with my Coreldraw 2020
Everytime I try and cut I get an error message
Running Coreldraw not Found
Can anyone help?
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
StellaD
Post by StellaD »
You will need to download Cutting Master from Graphtec..
It is a free plugin which installs in CorelDraw and lets you cut direct (also works in Illustrator)
Make sure you have the full version of Corel though as I don't think it works with the cut price student edition.
Mrteajunkie
Has thanked: 6 times
Been thanked: 4 times
Post by Mrteajunkie »
Ditch Corel and go with sure cuts a lot pro.
So much better and easier to use.
Mrteajunkie;144737 wrote:Ditch Corel and go with sure cuts a lot pro.
I'm with Mr T on that. I've used it for well over 5 years now for all of my cutting.
Quinsfan
Post by Quinsfan »
Why ditch corel if that is what the OP has always worked with? They may use it for other work not just to cut stuff, not a really helpful answer. I have an old Graphtec 7500 that is connected to an old XP laptop, which is not connected to the internet, but to my network, that I use for cutting my garment vinyl. This is because I have a workshop and studio. I can open the file on the XP laptop in an old version of coreldraw and then use cutting master 2 to cut the file.
Or as the second poster says try the Cutting Master download and see if that connects.
